I love the gurgling sound of an inboard spillin water.
I have a dumb guy question.
Can this boat use a freshwater cooling system, so you never run saltwater through the Nanni and only an exchanger?
LB26
Re: LB26
Morning Guys
Sorry for the lack of posts, the old back decided to give way again so not much work done in the boat shed...
Dan I have a dumb answer ! you have got me there I can not find any info at all on fresh water intake to the engine, I have asked questions and no replies.
I have started to install the Fuel tank / waste tank / water tank and general plumbing and ducting. Now waiting for my back to get better a parts to arrive, it has been the Athens boat show so all suppliers had closed down !!!
I feel like I my have a barrage of questions over the next few weeks as I am going off piste....
1st I have attached a couple of sections out of the Nanni installation manual. I can see how I get the air into the engine compartment but exiting the warm air I not sure how this can be achieved as per the top box of the attached ?
2nd Air vent on the fuel tank, does this just have to vented outside the tank compartment or through the hull ? the manual shows a diagram that suggests the vent just goes through the bulk head.
I will attach some photos of progress, I have started to position ducts with draw cords along with the tank plumbing etc. I hope to get back at it later this week
Cheers
Les
Cheers
Les
Re: LB26
I would think your air outlet would be on the top deck,
/gunwhale aft section of the boat and covered with a clam shell. You can opt to add two clamshells for looks, but the intake does not need to be the same place. I wpuld put it off the back so that engine noise coming from the intake is behind the engine and not by you...
The intake needs to consider noise. All the air intakes I have seen were in the doghouses. Running any engine air into the cuddy is a bad error. So, I would intake from under the aft deck and outflow on the deck top.
For safety, I would install a CO detector that has a meter somewhere near the helm to make sure any exhaust leak (a 20 year from now failure, for example) is not sucked back onboard by simple vacuum created by the cabin and movement of the boat.
Re: LB26
Morning All
Dan, thanks for the reply. I have attached details from the drawings and spec that relates to this issue. Jacques if you are around can you please help with the following.
The air intake is not a problem, I can duct this down to below sole easily Nanni ask for this to be at the front of the engine. The problem is expelling the waste air, Nanni show this being above the engine I take it this is due to hot air rising. This is obviously not possible with the LB26 design as the engine is isolated in the middle of the sole and the top of the engine is 380mm above sole.
Dan I can not see how I can get ducting under the sole to the aft of the engine as the compartments are full of tank, muffler, ducts etc and this again would be below the engine.
The problem is I am in the situation of trying to adhere to the Nanni guide lines and build the boat that Jacques has designed, ( I do appreciate Jacques that regs etc will have changed since this boat was designed )
Going back to my previous post regarding tank venting. I have just read Blueflood's post. If I understand this right the tank vent has to go through hull port or starboard with a swan neck to help prevent water ingress ??? The tank compartment venting I am still not sure about. My tank as per my last post can be seen centre of sole. I can just about get some ducts in and bring these out in the rear U shaped seating with vent grills. this will mean though it will be in the cock pit. Is this ok ??? If not any suggestions ?
Cheers
Les
Cheers
Les
Re: LB26
Fuel tank compartment vent off the stern. Suction there can reduce smells in the boat. You can clamshell it.
Blackwater tank best to have dual vents, or one larger one. Also, overboard and aft is better so when you run the odors pull away.
Venting to the inside of the boat is just not wise because any odors of say a tiny bit of oil on the engine burning off will leave the stench inside.
Mechanical blowers are required on gas engines because fuel vapors can build and are highlt explosive. I don't belive this is required for diesels. The most common place for blower exits is aft either off a gunwhale/deck or high on the sides via covered vents.
Do not worry if ducting moves up or down a bit. A well placed exhaist vent and clamshell will develop a bit of suction and pull vapors of b/w tank, engine compartment, fuel tank compartment.
There is a rule that fuel tank vents are not allowed to be near compartment vents. This is to avoid backflow
Of tank vapors into cockpit/liv spaces (15" rule)
Les-do you have a surveyor or need one for insurance?
For my boat, I hired a surveyor early and retained him and he agreed to take calls and emails and bill me time and this helped me with uncertainties. Some of the rules you may need to folllow may vary to ours.
Re: LB26
Vent engine compartment with blower. This will allow you to run the duct “the wrong way”. That or you’ll need to top vent the housing. I personally wouldn’t want that.
Re: LB26
Les one thing I I did not see answered was the fuel tank vent. It must vent outside the hull, here are some from the store here as examples for you https://www.boatbuildercentral.com/prod ... rap-vents/ You also put a loop in the vent line to prevent water ingress to fuel tank. Most of these that I have seen go out the side near the fuel tank under the rub rail. If you read through the description of the vents, I noted earlier they meet H-24.
Re: LB26
Morning
Cheers Dan / Jaysen / Tom
Thanks for the feed back guys, will vent the tank through hull and I have decided to fit 2 Vetus extract fans and vent aft through Clam Shells.
Just when you think you are getting there..... there is always more !!!
Dan regarding Surveyors and insurance I am in contact with a surveyor and he is helping me with a kind of check list as we go, he will also do the final survey and tonnage. Insurance I have not tackled yet !!! Although I do have a good mate who lives in Athens and is an x Lloyds guy so fingers crossed.
Cheers
Les
Cheers
Les
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
