Pultruded fiberglass
Posted: Tue Mar 16, 2021 9:44 pm
Has anyone here used pultruded fiberglass sheets to anchor screws for things suck as towers or hatch covers? If so do you have a source to buy from? Thanks
https://community.boatbuildercentral.com/forum/
https://community.boatbuildercentral.com/forum/viewtopic.php?t=65590
Not familiar with the term pultruded but are you talking about products like g10/FR-4? If so I used it as a backing plate for any high load hardware like cleats, eyes, and rod holders. Also inserted it in each hatch and drilled and tapped for hinges. I purchased sheets from Jamestown Distributers: https://www.jamestowndistributors.com/p ... etail/8758 and tubes from mcmaster: https://www.mcmaster.com/garolite/multi ... fr4-tubes/. Mcmaster has a huge selection of all types but isn't cheap.
Yes, this is exactly what I was referring to. Thank you very much.joe2700 wrote: ↑Wed Mar 17, 2021 8:55 amNot familiar with the term pultruded but are you talking about products like g10/FR-4? If so I used it as a backing plate for any high load hardware like cleats, eyes, and rod holders. Also inserted it in each hatch and drilled and tapped for hinges. I purchased sheets from Jamestown Distributers: https://www.jamestowndistributors.com/p ... etail/8758 and tubes from mcmaster: https://www.mcmaster.com/garolite/multi ... fr4-tubes/. Mcmaster has a huge selection of all types but isn't cheap.
Wow! That's amazing. I ordered a sample piece to test with. Thanks again.joe2700 wrote: ↑Wed Mar 17, 2021 11:57 am No problem, FYI I was super impressed with its ability to hold threads. I did a test where I drilled and tapped 1/4" g10 for 8-32 machine screws. Testing to failure the threads on the stainless screw failed before the threads in the g10. It was also very easy to tap(but probably dulls the tap quickly like everything else you cut g10 with).
