This is what I am seeing that looks like a hook. I jist did a finger sketch, which is exaggerated the other way...hook will steal performance badly, the boat will be slower and cost more in fuel..sometimes results can be very bad, so please run a string test, some of the pictures have different color plate on the aft section, so it may be an ilusion, but it looks like 15mm of hook..
Aluminium boat building - 25ft fisherman
Re: Aluminium boat building - 25ft fisherman
Looks good guy.
Hi, many thanks for your observation, i will check it for sure.fallguy1000 wrote: ↑Tue May 11, 2021 9:04 pm This is what I am seeing that looks like a hook. I jist did a finger sketch, which is exaggerated the other way...hook will steal performance badly, the boat will be slower and cost more in fuel..sometimes results can be very bad, so please run a string test, some of the pictures have different color plate on the aft section, so it may be an ilusion, but it looks like 15mm of hook..
Probably it is an ilusion but is always better to double check, maybe could be because the bottom plates are only tack welded inside on aft side of boat.
Just in case at this stage of work can be easily adjusted by using a lifter from ground.
I will let you know and many thanks again for observation.
I hope I am wrong!
I like the hull shape!
Finally i've been able to step forward on my project!
Basically the bottom shape is done, lateral chine steps as well, tack welded, i will proceed later on with full weldings.
In order to close gap on keel line i will use ceramic for full penetrations welding, actual gap is around 20mm, probably i will be able to close a bit more and reduce some millimeters.
I used 0.5 and 1 ton chain blocks, belts and hanging devices for plates but at the end result is very good and i'm so proud of that.
Now my big question is:
- do anybody have some drawings for bottom hull steps? i would like to install befor turning upside down...
Thanks, Cheers!
Thanks, Cheers!
- Attachments
- Forum.jpg (60.31 KiB) Viewed 825 times
- Forum4.jpg (107.05 KiB) Viewed 825 times
- Forum2.jpg (92.21 KiB) Viewed 825 times
- forum1.jpg (109.85 KiB) Viewed 825 times
That is some fine looking work right there! Not sure what you mean by hull steps maybe someone else will know
- Netpackrat
This is awesome and I am glad to see people doing the hard work of converting some of these designs to aluminum construction.
Do you mean strakes?
For the keel and hull steps(strakes) they should be in your plans. First the keel should be a 1 x 2" skeg running from about a 18" from the transom to 13-15' forward. This will be your best help in tracking in all seas and in turning. Next are hull steps or strakes which when properly designed can help in planing. There is a section somewhere in here that discusses this. These could be flat for 3-5" out and straight down to the hull. Do not put them over the stringers as you will want to tow your boat with the stringers over the trailer flats.
I hope that helps.
I hope that helps.
Great point on not locating on the stringers Tom.
Users browsing this forum: No registered users and 28 guests
