Aluminium boat building - 25ft fisherman
lucastefanel
Post by lucastefanel »
Hello,
finally i started to make real my adventure.
Starting from very amazing CS25 plans i adapted the boat on what i'm looking for and what i really need and together with my very good job experience with Aluminium 5083 i decided to build my dreams boat.
As suggested by Jaques on my previous topic i made some adjustements based on the fact that i'm not building the boat in fiberglass but in aluminium, after that i reviewed nestings and i sent first plates to cut.
After some weeks i received a huge pallet around 6 meters long with bottom plates together with frames and bulkheads.
I'm keeping track on youtube of my progress, the link is: https://www.youtube.com/channel/UCNlTzp ... rcVv6LpEJQ
Here i would like to share with you some pictures of progress in order to get some feedbacks from your side.
Cheers!!
Luca
cracked_ribs
Re: Aluminium boat building - 25ft fisherman
Post by cracked_ribs »
Very cool! I have often been curious to see one of these go together in aluminum. That's a very popular material where I live, but not often for home builders!
I designed my own boat. This is the build thread:
viewtopic.php?f=12&t=65349
Jeff
Post by Jeff »
Luca, Welcome to our Forum!!! We look forward to watching you build!!! Again, welcome!!! Jeff
Matt Gent
Post by Matt Gent »
Super cool project!
A friend and I want to learn to weld. We are tinkering with adapting a small S&G skiff (Lillistone's Fleet) to Aluminum as a "senior design project"' once we have the hang of it. CS25 is on a whole other scale!
Aluminum boat building seems to be very regional. The petroleum industry in the gulf supports a bunch of Louisana builders, plus the PNW. I'd think it makes sense for low production / semi-custom boats elsewhere but tradition seems to reign.
Dan_Smullen
Post by Dan_Smullen »
This will be a great project to watch!
Cowbro
Post by Cowbro »
Matt Gent wrote: Wed Mar 24, 2021 12:29 pm Aluminum boat building seems to be very regional. The petroleum industry in the gulf supports a bunch of Louisana builders, plus the PNW. I'd think it makes sense for low production / semi-custom boats elsewhere but tradition seems to reign.
I have looked into it for a bit, there are plenty of options out there to order a CNC cut aluminum boat kit for anything from a 10' dinghy to a 40' trawler, the problem lies mostly in the construction technique. There isn't as much information out there like there is for S&G boats. If your welder settings aren't dialed or you weld something out of sequence you risk turning the whole thing into a giant curvy noodle. It also requires some much tighter tolerances for fit-up. You can't just pile in thickened epoxy to fill a 1/2" gap.
Luca, I am watching this with much interest, it seems like you are off to a great start and seem to be more than capable. 8)
MikeyGnz
Post by MikeyGnz »
Hi Luca
I've been building a GV10 in alloy as a practice project before I build a kit-set boat. See My Build for more details. Just looking at what you have done so far you seem to be a better alloy welder than me and are using heavier plate/sheet so you shouldn't have as many distortion problems as I had. Looking back on my experience the two main things I learned were:
  • Do a lot of practice on off-cuts to get the welder settings and technique dialled-in. Once confident everything is correct, do more practice.
  • Short welds then let cool to reduce heat build-up.
Looking at your welds and gear you probably know all this already though.
Good luck with the build, I'm looking forward to see how it all goes.
Mike
TomW1
Post by TomW1 »
Luca I look forward to following your build until you launch it. I know you will need to prime it with zinc chromate before painting for corrosion protection. What aluminum alloy are you using 5053. I worked for a major aluminum company. :D
Regards, Tom
lucastefanel
cracked_ribs wrote: Wed Mar 24, 2021 11:08 am Very cool! I have often been curious to see one of these go together in aluminum. That's a very popular material where I live, but not often for home builders!
Hi, you are right, is very used in other parts of world instead of italy or europe in general but i think is more easy to work compared to fiberglass but this is my personal opinion :D
lucastefanel
Jeff wrote: Wed Mar 24, 2021 11:19 am Luca, Welcome to our Forum!!! We look forward to watching you build!!! Again, welcome!!! Jeff
Many thanks Jeff 8)
