The primer you are using should specify. I believe 100-120 grit for the system 3 primer, 100-150 for alexseal finish primer. 120 should be a safe bet unless your primer calls for something else.MarshallTX wrote: ↑Tue Oct 25, 2022 5:16 pm Any guidance on grit# before priming? I'm a few days away (I hope) and wondering if there is a good technique.
Marshall's FS17
Re: Final sanding before prime
Re: Marshall's FS17
Joe - Had not yet picked up the bucket of primer until our response. You are correct. I've got SystemThree and it recommends 80-120. Much appreciated!
Re: Update
Skeg
Re: Update
VIDEO of first coat: First Coat
Re: Update
Built cradle after first coat of paint. Second coat was applied after cradle was removed.
