The best place for fuel tanks in most planing boats is closer to lcg or longitudinal center of gravity. The boat's behavior will be more consistent empty or full tank this way.
A livewell forward is a much better way to manage load. My well in my aluminum 16' is 25 gallons and I usually always fill it when alone; for an offsetting me and motor 200 pounds versus your 12 gallons at 6 pounds or 72 pounds full only fuel tank.
So, not really a fan of the idea.
Marshall's FS17
Re: Marshall's FS17
I put my tank under the front of the console between the stringers. I like this approach because there is not much change in how it floats full to empty, and it was much easier to deal with fuel fill and vent as its just stright up to the side of the console. I also put the batteries under the console, but separated from the fuel.
But depending on the size of the console or if you have one at all that might not be an option.
I went with a 22 gallon tank for the occasional long trip but given the fuel economy with a 60HP modern outboard that is certainly overkill, I only end up filling up a few times per season. 12 will feel like plenty and you could probably do smaller and just have a way to connect an external tank for any extra long trips.
I did find the specified sole too flexible and ended up adding batons underneath, would have gone with thicker plywood in hindsight. I think you are right to be thinking about that.
Re: Marshall's FS17
Jmk, fallguy, and joe - Many thanks. I'll continue to go through the forum and gather ideas. Greatly appreciate your inputs. - Marshall
Insurance boat/trailer in TX
I'm looking for a company that will insure my FS17 and trailer in Texas. I've reached out to a few of the big names and they don't like home-built products. Any suggestions?
Boat and Trailer Insurance TX
Re: Marshall's FS17
No experience here, but old internet stories say you may have better luck insuring a custom boat than a homebuilt boat.
Re: Marshall's FS17
Narfi is right. Call it a "custom Bateau Boats Fast Skiff 17". Mine is insured with Castle Key insurance.
Re: Marshall's FS17
Did you all need a survey or appraisal first? I have liability coverage but to cover the boat itself my insurance company(amica) said they would but needed an appraisal first to establish the value. Haven't gotten around to it yet.
Re: Marshall's FS17
Joe, Cape Man, and Narfi - All good inputs as I'm learning this. Most companies have simply rejected home builds. I have found a few that might insure (pictures required, other unique requirements, etc.). Many thanks! - Marshall
Re: Boat and Trailer Insurance TX
It isn't homemade.MarshallTX wrote: ↑Fri Dec 08, 2023 1:08 pm I'm looking for a company that will insure my FS17 and trailer in Texas. I've reached out to a few of the big names and they don't like home-built products. Any suggestions?
It isn't wood.
It is a custom made composite FS17 runabout.
