PH22 alternate layout
fallguy1000
Post by fallguy1000 »
So, considering the pH22 for a bay boat for Texas and wanting to use it as a Plan B boat for bad weather.
A drawing with a few questions.
First of all, the aft bench really hogs fishing space. Can the forward frame be made sides and sole only?
Second, can I make the blue areas into seats? Or is the splashwell BH gonna need to be all the way up? If so, I can livewell those areas; otherwise, I would put livewell up front.
I want to make the boat comfortable for six adults with four fishing. If all four can't cast; we can probably cork fish one guy, but the seating needs revision.
The 'bench' as drawn here doesn't even look like a bench.
I can't add a picture here; darnit...I'll put a picture in the repair forum.
viewtopic.php?f=12&t=62495
jacquesmm
Re: PH22 alternate layout
Post by jacquesmm »
I replied to your other post.
What you see in the back is an aft deck. Builders use it as a storage place with things like tackle boxes under it and put cushions on it when they have passengers. With the cushions, it becomes a bench. You can modify it the way I described it in your other post; leave it under the sole, leave 3" above all around.
When modifying it, keep storage in mind.
You can eliminate the motorwell bulkhead but that becomes unsafe.
