This question arrived via email earlier this morning: Hi, I have two simple questions. What causes the side panels of a D5 dinghy to be wavy on the bottom side of the hull?
How can this be corrected? Best," Jeff
D5 Dinghy Questions
Re: D5 Dinghy Questions
In my opinion ... (opinions are like...)
Assuming it is on the bend plane...
• Frames may be misaligned.
• Variance in the wood grain or glue layer.
• Optical illusion
Try running a string from bow to stern pulled tight. If the high spots align with frames then check all your measurements. If the string touches the side the whole way it is an illusion. Anything else would make the wood suspect.
A picture would help a bit.
• Optical illusion
- New Poster
Thanks for your response on the D5 Wavy question. This boat was built by a group of 9th grade high school students and as such was left in their care to
construct and complete. Upon closer examination I discovered that the Transom is misaligned by 2 inches on the right - hand bottom side. The framing in this area is
also misaligned. It would also appear that the lumber used to build this boat is of different types- marine plywood for the transoms, exterior grade plywood for the
bulkheads and lauan for the sides. This was determined upon removing some of the encapsulated epoxy and fiberglass cloth used in the boat's construction.
I suspect that these factors have contributed to the wavy bottom problem. At any rate I can use this boat as a teaching tool to
explain how not to build a boat, teach the students how to correct the errors, emphasize the importance of taking and applying accurate measurements, and how to
properly align frames and bulkheads. I have come across this problem once before several years ago. However, it was not as severe. We merely had the students in
that case replace the side panels with new skins. Thanks for your help. I'll keep you posted on the corrective action taken.
Best,
Henry
Best,
Henry
That would be the problem. Luan typically has voids and unknown quality/consistency of glue. This will result in unpredictable bending even with all other factors being perfect. That said, I recently saw a "luan skiff" used as a boat dinghy for a moored sailboat. Ugliest thing I've seen, but the groceries and laundry arrived at the boat with no problems.
