DE 27.5
TomW1
Re: DE 27.5
Post by TomW1 »
Looks really nice and ready to go. Tom
PapaDave
Re: DE 27.5
Post by PapaDave »
Nice progress. Where are you located in Ct?
Dave
dennisb
Re: DE 27.5
Post by dennisb »
made progress today. Three layers of tape on everything except the transom.
dennisb
Re: DE 27.5
Post by dennisb »
Making progress. Put one coat of glass on the bottom and transom this weekend. Sanded it out this afternoon.
fallguy1000
Re: DE 27.5
Post by fallguy1000 »
Make sure to get all the dust off before next step.
viewtopic.php?f=12&t=62495
dennisb
Re: DE 27.5
Post by dennisb »
Looking for guidance.
The plans don't call for a drain plug. Should I consider installing one ?
I have had boats with and without drain plugs. I could go either way on this.
Thanks in advance for your input.
Dennis
OneWayTraffic
Re: DE 27.5
Post by OneWayTraffic »
If you have a bilge at the transom then you will need to drain it. No bilge, no drain. Your choice. Scuppers out the sides would work.
On my C17 I'm putting both, but my boat will probably not self bail except when empty. I'd expect yours to self bail regardless so it's an option you could skip.
dennisb
Re: DE 27.5
Post by dennisb »
Thanks OneWay. I am planning on installing scuppers.
fallguy1000
Re: DE 27.5
dennisb wrote: Fri Jun 17, 2022 8:13 am Looking for guidance.
Dennis
Always tricky to decide how to build these. Me, I'd limber the entire boat, lay down plastic, foam the sole, run the limbers to a sealed off dry sump well. Not even wire a pump, but have it on standby. Monitor the sump with a plastic pie eye, or a piece of acrylic bedded into butyl. Then, you know, on a 27 footer, it she's leaking somewhere.
This means no drain plug.
Edit: Assumes plenty of scuppers at sole height! You can also add a wet bilge well along with a dry one.
TomW1
Re: DE 27.5
Post by TomW1 »
It sort of depends, you have that big cockpit that will get a lot of rain in it plus the run off from the pilot house. It will need to go some wher.e. So either a drain hole or a pump if your docked or on the water. I would go with an automatic pump as primary and a back up in case the primary failed. If you take to much water on back there you can scuttle the stern. On smaller boats a drain hole works well. The plans for the C19 calls for a drain holl as it is expected to be trailered.
Users browsing this forum: Yandex [Bot] and 3 guests
