Requiremetns: 2 person crew, mostly cruising around US/Canada/Mexico coast. Longer trips to Caribbean/Central America. Extended offshore periods if desired.
First tasks:
Yesterday I traced the large-sheet plans onto paper for making an initial paper model. Doing this really helped on our previous build. I'll then modify the initial model based on some changes I'm considering and will make sure I'm happy with any such changes - nothing too drastic - the design is well-proven already. Next, I'll make a rigid scale model out of balsa wood to the final planned design.
Until spring 2023 I'll sadly still have to work so will be completing some of the smaller self-contained tasks that can be done prior to the hull build. Brian, a VG23 builder in the UK, advised doing as much of the smaller stuff as possible first, since once the hull is built working space is vastly reduced. Makes a lot of sense. So the plan will be to construct chainplates, ruddder, keel, centreboard etc., prior to getting started on the hull.
Let's see how it goes. Based on the previous build, I think it is possible to be completely finished and in the water in under two years - sailing is the goal, rather than building. But of course, I will no doubt smile ruefully to myself when I re-read this post in the future...
Mick
