Cold climate epoxy users please HELP!
Re: Cold climate epoxy users please HELP!
cape man's instructions are good advice. Start with the acetone and clean up with the white vinegar Feel for you guy. Tom
Yes, lots and lots of white vinegar and acetone and a good scraper.....ask me how I know...
Obviously this is not your fault since the supplier messed up. You should ask when they're coming over to help wipe it all off
Eric (aka, piperdown)
For reasons like this mislabeling or other manufacturing defects I suggest mixing a very small test batch of epoxy and making sure it kicks in the expected timeframe. I had a batch of slow cure gel magic that was labeled as normal and while it cured eventually it wasn't behaving as expected. I've done a small test batch with each product ever since then.
I might demand a refund instead of replacement if this supplier hasn't been good to work with, but they will all limit their liability to the cost of the product, not any costs you incurred beyond that. Hope you can save the wood.
I do not like using heat much, but might be needed.
If biax glass; remember to pull both layers! Ask me how I know!
I was pretty sure it was a mix or stir error, but sux they gave you an error. Terrible.
I had a bad batch when making my CC14 canoe - I smelled like white vinegar for weeks.
I also remember a bad batch on my V12 sailing dinghy rudder…. It’s horrible stuff to clean, but that’s why we love it, it STAYS ON!!!
I’ve just reversed the ratio as a test and made a batch of 1:2 instead of 2:1 - it’s getting hot in the measuring cup and I think it’s setting.
I’ll mull on this for a day or so and wait for further follow up from the supplier.
I won’t share the brand name just yet as I want to see if they’re going to assist before trashing their name over the internet.
I’ll keep y’all in the loop.
Thanks again for all the responses - really appreciate it.
Cam.
Cam.
Completed:
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
Really sux for you and I hope it comes off with not too much work, but that might be just a dream.
Nice thing about Marine epoxy and System Three is the resin is sort of clear and the hardner is enough darker to tell them apart just by color.
1 part medium hardener mixed with two parts of slow hardener will not get hard when wetting out the glass for the sole on an OD18! You can get through it...
Final update,
Looks like it's confirmed that the labels were on the wrong bottles. My test batch with ratios reversed has set without issue.
The resin came in 6 x 1L bottles, 4 of them part A and 2 of them part B, so aside from the initial part A and B bottles that I used I don't know which of the others have the same problem. The bottles are all the same shape, size colour and odour so I can't tell if they're correctly or incorrectly labelled and hence cannot continue with this resin.
The supplier offered to send me 6 more litres assuring that they will be labelled correctly however I'm unaware if I can trust this so I've instead asked for a refund and they have apologised and obliged.
I suggested to them in future that they make their Part A's and B's come in different shaped/coloured bottles, they said they'll take that on board.
No luck getting new ply as expected. I'm going to shelve the boat for now unfortunately and come back at it once I know I can get my old favourite epoxy again.
Thanks
Cam.
Thanks
Cam.
Completed:
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
Users browsing this forum: Google [Bot] and 8 guests
