FS14LS Build in Waco, TX
Re: FS14LS Build in Waco, TX
Yes, I think I’m trying to overthink it…stick to the plan…
Got the plywood kit yesterday and cut the tabs today…ready to start assembling! So, does it matter which side of the stringers the butt blocks go on? Inside or outside?
Also, considering weighing all the pieces before assembly…to add to VT Jeff’s weight data
Ok, I weighed the kit pieces on a postal scale and they total 104.8 lbs, including frame/mold C, which will lose about 1-2 lbs when cut down later.
This does not include the bow mold, 2 sheets 9mm okume (nominally 31lbs each) for the deck, rubrail, or cleat material.
So out of 3 9mm sheets + 4 6mm sheets (177lbs), we have used 104.8 lbs…approximately 40.8% waste.
I’ll try to keep track of wood weight as I go, if I can remember…
Josh,Josh_From_TX wrote: ↑Tue Nov 01, 2022 9:11 pm Got the plywood kit yesterday and cut the tabs today…ready to start assembling! So, does it matter which side of the stringers the butt blocks go on? Inside or outside?
It doesn't really matter what side you put the butt blocks on the stringers.
-Reid
- Steven Wright
- Steven Wright
Josh_From_TX wrote: ↑Tue Nov 01, 2022 10:29 pm Ok, I weighed the kit pieces on a postal scale and they total 104.8 lbs, including frame/mold C, which will lose about 1-2 lbs when cut down later.
Great info! I did not expect that level of waste, I need to revisit my model.
Thanks, Reid...just wanted to make sure. Now, on to the transom questions. The kit came with 3 complete transom pieces. The notes say to use 1 or 2, or 1 with a clamping board. I'd like to use 2 whole transom pieces and plan to use a 20hp or 15 hp (nominal weight 97-107 lbs). Don't think I'll want to go with a 25hp. The plans/notes say if using two whole transom pieces to cut 3/8" off the stringers for the additional transom thickness. This is my plan...will the transom be strong enough for a 20hp this way? Is there anything else I need to do with the kit pieces?
- Josh
Josh,
Even though there are options for transom thickness, I would go ahead and install/laminate all three transom layers that came with your kit. The weight difference would be negligible and this would allow you to use any HP motor (within reasonable limits of course), in case you wanted to upgrade later on. Once the transom is laminated you would simply need to dry fit it to the hull/bottom panels and remove the appropriate length off the back of the stringers.
-Reid
-Reid
- Steven Wright
- Steven Wright
About ready to join the kit pieces. Everything is “easy” so far, but I did think the puzzle joints were supposed to be tighter. Do I need to fill in the gaps with thickened epoxy or just coat edges with thin epoxy and tape the inside side? The tutorial made it sound like I’d have a really tight fit. Thanks
Gaps are no problem and almost always desirable. seal edges with raw epoxy and fill any gaps with thickened epoxy before taping.
Users browsing this forum: Bing [Bot], Yandex [Bot] and 5 guests
