Well, here goes...finally ordered the plans for my first build. Thanks already for the welcoming and supportive attitude from Reid. I look forward to this process.
First things first...kit or cut at home? The only lumber I can get semi-locally is Meranti, so cutting at home will immediately add 50+ lbs to the hull from what I can discern. I'd like to go as light as possible because I know I'll use more epoxy being a first-time build. I don't need to be ultralight, but planning to run a 15 or 20 hp and would like to save weight where possible in the build.
The plywood cost for the kit will be more than double what I can get the meranti locally for. Is 50ish lbs weight savings worth the extra $1,000+ in plywood for the okume kit?
I'd love to hear some opinions from experienced builders...thanks!
Josh
FS14LS Build in Waco, TX
Re: FS14LS Build in Waco, TX
Welcome Josh!
Good question on the Meranti vs kit. A third option may be just the plywood from BBC but not a pre-cut kit, not sure what the savings there would be if any. If it were me, I'd probably spend the extra $$ on the Okume. Cutting out the panels is a fun, rewarding part of the build but it's a relatively quick, small step in the overall scheme of things. If I were to build another I'd probably start with a kit.
If you're gonna go with a 15, plan on keeping it very, very light, which is a good way to go anyway. I did some calcs on the weight of the BOM on this boat and by my calc, the listed design weight of the hull is low by about 50%. You can run your own calcs and see what you get.
Jeff
Jeff
Thanks, Jeff. Your posts about hull weight and your calculations were what got me thinking about this. Theoretically, the meranti would add ~55lbs over okume to the plywood weight on the BOM. With a hull weight of 190, that's adding about 29% (with no waste factored in) ... looking at it this way makes it seem like more than "just a few extra pounds." Even with a baseline okume hull weight of 290, those extra lbs. of Meranti could be 15% - 20% added to the weight.
Also, I don't think I'd miss any fun by not drawing and cutting it myself! I'm attracted to the time savings of a kit as well.
Yep, agreed.Josh_From_TX wrote: ↑Fri Oct 14, 2022 1:34 pm Also, I don't think I'd miss any fun by not drawing and cutting it myself! I'm attracted to the time savings of a kit as well.
Motors, trolling motors, trailers, electronics, batteries, etc: These things can all be easily upgraded later. The hull cannot, so it's traditionally not a great choice to shave cost.
Agree with Jeff in the overall scheme of things the plywood hull will account for only 10-15% of the boats cost. Then you start adding on the fiberglass the paint the hardware the motor, etc, etc. So, it is your choice whether to buy the kit to save the time and save some weight and time or buy the meranti locally and cut it out yourself. Tom
I bought some okume from a lumber yard in Austin a few years ago. Can't recall the name but it's in north austin, east of I 35. Also there's a good one in Houston that may well carry Okume. Might be a day trip would save a grand. The cut out is no big deal, just a weekend or two. Worth looking even if you go with the kit 'cuz for whatever reason you may find out later you want one more piece.
Dougster,
Thanks for the information. The Austin supplier is called Fine Lumber...they don't carry Okume, but from what I've read they used to.
I hadn't looked in Houston until I read your post. Houston is about 3 hours away from where I am, so a very doable option. I did a little research and found a supplier there with Okume in stock...Houston Hardwoods.
Thanks for leading me in this direction!
They are who I buy my plywood from. They have some really nice wood there and are proud of it. The plywood is close to the same price as BBC... just a little cheaper. They are less than a mile from me.Josh_From_TX wrote: ↑Mon Oct 17, 2022 8:58 pm Dougster,
All the info so far is very helpful. I now have two good options for okume plywood that will keep the boat light...kit or the supplier in Houston. While I consider that decision, I also want to plan for the eventual installation of the outboard.
I'm new to the building and outboard sizing game, so should I build the boat with the transom designed for a 20" motor, even if I plan to get a 15" motor? I have read that 15" doesn't always mean exactly 15" on an outboard. I'd like to keep this as simple, light, and clean as possible, so I want to avoid using a jack plate. Do I need to know the exact measurements of the motor I'll use prior to finalizing the dimensions of the transom?
Easier to cut the transom down than to build it back up. If you do not know the length of the motor you are going to get, then build it for a long motor. Once you get the motor you can then measure it and trim the transom, if needing it, to that size.
Users browsing this forum: TommyD and 6 guests
