How do y’all clean them? At the very least, they’ll slowly fill with epoxy, right? Are they semi-disposable in that you can use them a few times before they’re too full of cured epoxy to be effective?
I cleaned mine with vinegar and a toothbrush, but since it was a long session, there is still cured epoxy toward the middle.
Jbo
Cleaning bubble rollers.
Re: Cleaning bubble rollers.
I wipe mine off with denatured alcohol on a rag. After several uses once the channels are filled up I burn the epoxy with a plumbers torch to make it charred and brittle then knock it off quickly with a wire wheel. I tried just the wire wheel but the epoxy is almost as hard as the aluminum so doesn't work well. Once burned it's easy, but do it outside!
Leave in acetone. Use dental pick to clean now and then. Got a whole boat from mine.jbo_c wrote: ↑Mon Oct 24, 2022 6:54 pm How do y’all clean them? At the very least, they’ll slowly fill with epoxy, right? Are they semi-disposable in that you can use them a few times before they’re too full of cured epoxy to be effective?
Jbo
If you are organised and can get it into acetone before it gels, all good. I'm not so organised, but a wire brush, heat gun and propane torch work too. Worse comes to worse, a few more metal rollers will not be the biggest wastage on the build.
- Knottybuoyz
MEK will melt cured epoxy. I keep a container with some in it to degunk bubble busters. A stainless steel wire brush makes short work of it.
Yours Aye! Rick
I'll have to try that. I was using what OWT and FG were doing, but sometimes I waited a bit too long to dump the rollers in my acetone pail. Then it was a pain to clean off.Knottybuoyz wrote: ↑Tue Oct 25, 2022 7:23 am MEK will melt cured epoxy. I keep a container with some in it to degunk bubble busters. A stainless steel wire brush makes short work of it.
Eric (aka, piperdown)
