Cavitation plate
Cavitation plate
Is there a consensus on how far below the hull the cavitation plate should be on a boat like the lm18 or fs18? I’m trying to fine tune my lm18 .
Re: Cavitation plate
In plane of hull bottom and even. If it comes out on turns; lower it. If it makes a deep vee in the water raise it.
Man I missed this back when you asked it. Normally the Cav plate shoul should be even with the bottom of the hull +/- 1/2". Too low and you're lugging the motor by having to push to mush water with the motor shaft, to high and you create ventilation making the prop ineffective. This is especially important for the FS and LM as they are shallow water boats.
Aim for higher that you think, but I built heavy. I get you some pics of mine when I get a chance. I still want to go up a hole or 2 and test it out.
See my LM 18 build here.
viewtopic.php?t=64254
See my LM 18 Questions here.
Finished Boat Here
viewtopic.php?f=25&t=65173
Finished Boat Here
Follow up, After a couple trips with the plate even to 1/2 in above the hull, I dropped it back to about an inch below where it originally was. With it up the boat was a little squirrelly, and sluggish. I still have the stock prop though. Also I didn’t gain anything. So apparently the sweet spot was where it was.
