I could give you those numbers. if I knew what the boat would weigh as it left the dock, people gear etc. Which brand of motor will you be using.
Let's assume 350 lbs for the boat, plus engine, plus 400 for people and equipment. The boat is 18 ft long but only 54" wide.
That is not the proper hull bottom to hullsides interface.JoRoesler wrote: ↑Thu Jul 13, 2023 6:06 pmGaps in the foam will be filled, and inside joints will be tabbed with 45/45 diagonal carbon tape.fallguy1000 wrote: ↑Thu Jul 13, 2023 5:17 pm What are you doing at the hull bottom/hull side interface and the hull side/hull deck interface(s)?
Jo about 30mph for the 20HP using Yamaha specs, you gain only 4mph to 34mph with the 30HP Yamaha. Jacques does not recommend more than 25HP which would put you at around 32mph. The 20 comes with a prop the 30 will need you to add a prop.JoRoesler wrote: ↑Fri Jul 14, 2023 11:46 amLet's assume 350 lbs for the boat, plus engine, plus 400 for people and equipment. The boat is 18 ft long but only 54" wide.
