Builders Forum
Builders Forum
Just checking the speed of the Forum. Jeff
Re: Builders Forum
Yes it was already much faster. It took 30 seconds before I got the reply screen.
Re: Builders Forum
Something is wrong for me. It is taking the forum too long to accept my replies (seriously).
I am wondering if all my posts are getting approved by DeSantis first (humorously).
Although this one went fine?
Dan
Dan
Re: Builders Forum
The same with me fallguy. I timed one and it took 20 seconds. Some go fine others are as slow as molasses. Tom
Re: Builders Forum
It’s all about backend services. Backups take time to run and when things go sideways… they go sideways. Sorry folks. Not much we can do about it right now.
Re: Builders Forum
I have to hit submit again and then it says I can't post again so soon. So, something happens, but it doesn't register back here.
Re: Builders Forum
Try hitting the recycle button after you reply. It sometimes help bring your post up.fallguy1000 wrote: ↑Sun Mar 19, 2023 7:48 pm I have to hit submit again and then it says I can't post again so soon. So, something happens, but it doesn't register back here.
Re: Builders Forum
Jaysen something is still wrong with the link. I timed out twice this morning sending a reply. A screen came up that showed the connections were fine till it got to Bateau and then an error 504 was indicated. I waited 5-10 seconds more and resent it and it went.
Re: Builders Forum
If you are using "Bateau" just as a habit, ok. But if you are on an URL that is bateau.com then you are "doing it wrong" somehow. Everything should be community.boatbuildercentral.com.TomW1 wrote: ↑Sat Apr 01, 2023 3:04 am Jaysen something is still wrong with the link. I timed out twice this morning sending a reply. A screen came up that showed the connections were fine till it got to Bateau and then an error 504 was indicated. I waited 5-10 seconds more and resent it and it went.
The timeframe of your post (3aET) is smack in the middle of server maintenance and backup. I would not be surprised by issues between 12:00a and 5:00a. Issues should not be long duration, maybe 20-30min, but there will be time in there were things are stupid.
Re: Builders Forum
Jaysen I got timed out just now 11:46am eastern. I checked and am using community.boatbuildercentral.com as you said in your last post to me said. This is not in the time frame you noted in your post. The timeout showed the Cloud*** in Atlanta good but that the problem was at BBC with an error message of 524.
