Wasn't asking for the chines, was thinking about other applications and was just curious if I could use a router bit on it. Like on a hatch for instance.pee wee wrote: ↑Sun Jul 23, 2023 10:18 am Routing plastic makes what looks like shaved coconut, except with static cling! If you need a big radius but the angle was greater than 90 degrees you could remove some of it with a router and fine tune with sanding, but I thought this conversation was about squaring up a radius with gel magic.
If all you need is a 1/16 or 1/8" radius, I would do it by hand. For a larger radius, a good technique is to begin by making a consistent size 45 degree angle, then make it round with a sander with a relatively fine grit. Much as I love routers, by the time you jump through the hoops necessary to use one on a boat, you could often do it by hand quicker.*
*That doesn't apply to things like hatches and bulkheads where a router is very handy.
RickW Ph18
Re: RickW Ph18
Re: RickW Ph18
Got reverse chines and strakes glued. Need to get outside and do a little sanding but the weather is not cooperating. I am trying to do any sanding in the garage. Ill get some pics posted in the next week.
My Golden does like the jig as a place to hide from the thunder.
https://community.boatbuildercentral.co ... b_Joey.jpg
Re: RickW Ph18
https://community.boatbuildercentral.co ... ?pid=75756
Too much of this and not enough work on the hull the last few days do to rain.
Re: RickW Ph18
Spent a few days correcting my mistakes, some of it hurt a little. I guess that's how we learn sometimes. I'm back to being ready to sand and start the fairing process.
https://community.boatbuildercentral.co ... play_media
Re: RickW Ph18
Boat is looking in good shape. That thing already looks fast!!!
Good luck with the rest of the build.
Mick
Mick
Re: RickW Ph18
I may look to sand tomorrow and begin fairing. Looking at the deepest low spot in the hull bottom that will need to be faired, It's along the transom, it looks to be about 1/4 inch. IS that to much to build up with fairing compound? Do I need to lay some glass in that low spot?
Re: RickW Ph18
I would lay some glass. 1/4" seems too much for fairing compound but would work with woodflour/resin mix. A little glass saves resin. Wait for others' ideas.
Re: RickW Ph18
I worked hard to get the bulkheads all level on the jig. From what I can tell, The transom was not level with the other bulkheads and is the reason the last 6 to 12 inches falls off to the 1/4 inch low spot along the transom.
Re: RickW Ph18
Hey Guys, back at this hell they call sanding the fairing compound. At least the weather is cooler. There are a few places I did a shit job of putting down fairing, or laid it on too thick. When I end up with a deep scratch, do I need to keep sanding till I get all the way to the bottom of the scratch or can I just fill it? Will fairing compound bond inside it with out sanding in it? Can I wire brush it to get a good bond? https://community.boatbuildercentral.co ... album=2165
Users browsing this forum: Ahrefs [Bot] and 1 guest
