Hi guy's been lurking for a wile now, Dad bought me plans for my bd some years ago now, father son project finally under way, my father has been/is doing the majority of the woodwork with his decades of woodworking knowledge and also completing a Green island 18 I've attached a photo for you guys to have a gander, ill be helping where i can but dad is happy doing those side of things as im good with the finishing, fibreglass, painting, electronic's, mechanical and trailer building, anyhow team work makes for the dream work.
Cheers
Panga 22
Re: Panga 22
For deck, we have brought this back somewhat to give us more sheltered area
Re: Panga 22
Top and bottom sides were tuff work to bring true and were left with some gaps around and inch or so between the tops of the frames, we decided to leave it at that and choose hull fairness following other's builds over putting more stress on everything, we are happy with this as the hull's curve's look good, the only other thing we did was drop the transom slightly and added a 5mm spacer between frame G and the bottom side to make the hull more straight looking down the length of the hull from the transom, we had a slight dip around frame G, happy with the results and everything is looking good.
Re: Panga 22
Im happy with my first taping efforts with only a minor blunder along the way with over wetting the first meter and had some runs ect, have learnt alot along the way and feeling confident about laying out the mat and the rest of the taping,
I read mention on here with a few people having dramas with bubbles getting stuck, what i have learned to counteract this is enough radius on edges with either round over's or fillets doesn't take much and fill in any deviation and smouth them out, other than that plenty of wetting out, patience with letting the reson soke in and using a stiffer bristle brush to poke into the white bubble working the brush in different directions to draw the resin into those tuff spots, just have to remember to move on the excess once sorted, that's where i went wrong in my first meter.
Re: Panga 22
Sweet boat! Looking forward to following along for the ride!
Eric (aka, piperdown)
Re: Panga 22
Nice work!!! Jeff
Re: Panga 22
Good moving focusing on fair and not every seam/joint looking perfect.
