Thanks to all for the kind words.
Today I finished the cross gunwale braces, filled and tabbed the keel seam, and removed ALMOST ALL the screws ... so far so good!
Dynamo..tabbing inside is a great way to keep the outside seams smooth. I don't think I could take all the bending and crawling that it requires though ... and of course using the 'non-split method' I needed LOTS of tabs.
I'm going to make mine "smooth" with the belt sander (being carefull not to cut the tabs themselves of course)...then I'll be ready to biax the seams.
Tomorrow's probably going to be a Tyvex and respirator day!
Panga 20 West Central Florida
Only a small amount of work today...filled the last few gaps..tabbed the last of the keel seam at the bow..and sanded the chine tabs smooth on the starboard side...almost ready to biax all seams ...and only 4 screws left!!!... It really is possible to bend the 3/8" meranti to the Panga 20's camber requirements ..using kerfs.
A BIG day...ALL screws removed and no firewood !!
Completed smoothing and biaxing the keel seam...next, a couple of short seams on the transom and then on to the veil!
As I begin to contemplate the fairing I must say that the 1 1/2 gal Quickfair kit looks mighty small sitting next to the hull. I know..."put it on thin"...but still
The trick, I think (and after 4 boats I'm still not sure I know the right way), is to get the fairing compound in the "right" places, i.e. the low spots. I have found that putting it on with something as wide as possible helps - like a 12" to 18" wide semi-flexible spreader. Something that can conform to the hull shape, but not be so small or flexible that it scrapes away the fairing compound from the low spots. All that being said, I still have probably seen hundreds of dollars of fairing compound go up in dust as I sand it away.JASmine wrote:As I begin to contemplate the fairing I must say that the 1 1/2 gal Quickfair kit looks mighty small sitting next to the hull. I know..."put it on thin"...but still
Ralph
BRAVO!! Keep up the good work!JASmine wrote:A BIG day...ALL screws removed and no firewood !!
Building the FL14
Started by cleaning up the work area....sanding dust everywhere.
Did a couple of seams on the transom, prepared the wide cloth for the bottom application, and started the laminations for the rubrail. Ordered the S3 primer (white). I think I 'm going to use a very very pale blue for the hull color so the white primer shouldn't effect it from underneath...(I know it wouldn't anyway with enough topcoats )...but what the heck, everybody uses gray.
Taking a vacation day tomorrow ...life long friends visiting from up north.
Layed the starboard veil today..would clearly be easier with two people but you work with what you have......
It's not too bad a job but you do have to be quick about everything. I used the semi-wet on wet method..layed a layer over already coated wood and let it dry to tackfree (actually mine was almost tackfree..it's better to wait )..then layed the already cut cloth, then wetted the cloth (which took multiple batches of resin..this is where you have to work fast), then rolled everything smooth, then put the plastic sheeting on, then rolled and squegeed everything..then rested!!
Very nice . . . already ordering primer . . . woohoo!
I looked at your gallery this morning . . . She is looking super! Keep up the great work, JAS!!
Building the FL14
