Hey Jacques .... Is this going to become an option when ordering the XF20 plans?
Gary ............ great and wonderful work. I have friends in Oviedo that would say that's a "shrimping" machine .... lots of nice stable deck, plenty of room for 12Vs. But I think you'll be getting a lot more than shrimp guts on that fish killer!!!!
Waiting for the launch series!
Dave
XFS21 version of the XF20
- BilltheCat
- fishingdan
Thanks for the nice comments!
John
Yep the same stuff Steve used in his boat and applied the same way, drywall texture gun. Used small tip and about 70 psi for base coat and 30 psi for spatter coat. Bought a 5 gal pail and pulled out about a gal to have tinted an off color to help hide dirt and stains. Had the base coat tinted to match the access hatches. Used some for practise on scrap cardboard boxes and scrap wood. Never used a texture gun before but it was pretty easy to get a decent patter going. I have about gal and a half maybe two left.
It's Safety Deck made by Dyco.
The stuff went on great. The epoxy surfaces primed with S3 primer. It has a rubbery or gummy consistancy when it's dry. Great non slip surface. Don't know how it will hold up. Time will tell. Hope it does well. Saved a ton of fairing time and looks good. Can says to brush, roll or squeege on. Try that but it brings the git up to about a 10 grit sandpaper if there is such a thing. Way to rough for me. Texture gun was the ticket.
Thanks for the tip Steve !
John
Gah Dang!
I like that ! I thought about turning the XF20 into a scooter design by shortening the gunnels and decking the whole boat. IF ONLY I had the money. The trim tabs do well I guess? I noticed you chose not to use a jack plate. I don't know if you plan to run crazy skinny like folks here in the lower Texas Laguna, but a manual jack plate and a cavitation plate would skinny that bad boy up. The backspacing from the plate would let you raise the motor and the cav plate would keep the water down. I have them both on my OD 18 and I was able to raise the motor several inches higher without compromising performance or water intake. Someone once wrote to the that the OD 18 "aint no skinny" but she runs in less than a foot! without kicking up mud or sand. I love it! great work!
Daniel
Daniel
Users browsing this forum: Google [Bot], Yandex [Bot] and 11 guests
