knottyBuoyz III The TW28 Project
Knottybuoyz
Re: knottyBuoyz III The TW28 Project
Post by Knottybuoyz »
narfi wrote: Fri Mar 08, 2024 11:04 pm Sounds like a well thought out system! Will you have a start battery as well or will the wireless battery also be here for the engine?
I think I remember you were going to use a small gas generator. Are you planning on utilizing an oversized alternator for the house bank as well?
The starter battery will be stand alone and dedicated to just that task. The little Yammy rolls over very easily and won't take a huge battery to start it. The DC/DC charger will take care of keeping it charged.
We have a Honda 2000 watt genny installed in the lazarette.
I suspect we won't need it much unless we're cruising for an extended period of time and it's overcast. As long as we can run our refrigerator we'll be good for power. The engine has a 100 amp alternator right now. At some point in time, if we find ourselves needing more charging from it I have bookmarked a Balmar and surpentine belt & pullies kit. That's a little pricey at the moment so we'll wait to see how well disciplined our power management really is. Of course it's all speculation at this point. :lol:
Yours Aye! Rick
Knottybuoyz
Hey fellas. Still trying to get some stuff done despite the cold and wet weather here. Slowly inching towards spring. In today's update "You know you're making progress when you're drilling holes in your hull" edition! :lol:
This thru-hull will feed raw water to the head and maybe the anchor washdown pump. It's a 1" Forespar Marelon seacock with strainer.
The hole itself is 1-3/8". I opened up the inside laminate and removed the core.
The core removed displays the thickness of the bottom panel is, 19mm (3/4”) of which the outer layer of glass is approx. 5mm (5/16”) and the inner glass is approx. 4.5mm (1/8”). The black areas are the fiberglass.
I made up a backing plate and mixed up a wild mixture of milled fibers, cabosil and microspheres as a filler. I never use wood flour below the waterline.
After 24 hrs the epoxy mix hadn't cured so I had to put some heat on it for about 6 hours.
I'll redrill and finish the seacock install today. Weather permitting.
On a side note, every time I enter the v-berth I smash my head on the forward edge of the cabin top. :? :roll: So this was my temperary solution.
That's about it for today. Hope everyone is well and happy! Cheers!
Yours Aye! Rick
Knottybuoyz
Ooops forgot one.
Yours Aye! Rick
Knottybuoyz
Yours Aye! Rick
Knottybuoyz
Live now on YouTube our latest vLog update. What's the putz up to now? Drilling a BIG hole in my boat! You're gonna wanna to see this one! 😁
https://youtu.be/Ur5kyC4SOBY
Yours Aye! Rick
Knottybuoyz
Moving forward! Battens & bunks for the v-berth.
Top Secret Rum Locker
Cutting hatch openings in bunks.
Next video coming Friday @11:00 hrs EST
Standby...
Yours Aye! Rick
pee wee
Post by pee wee »
Looking good, but the rum locker looks kind of small!
Seriously, it's good to see you're still plugging along and actually getting there.
Knottybuoyz
pee wee wrote: Thu Mar 21, 2024 8:34 am Looking good, but the rum locker looks kind of small!
Rum locker should hold about 8 40 oz. bottles. I checked! :lol:
London Dock
Lamb's Old Navy
Pusser's Navy Rum
Newfoundland Schreech
Appleton's Estate VX Signature Blend
Kraken Black Spiced Rum
Sailor Jerry Spiced Rum
Bacardi Oak Heart Rum
It does not matter how slowly you go so long as you do not stop. --Confucius (551-479 BC), philosopher
Yours Aye! Rick
Jaysen
Post by Jaysen »
Seems a little light to me!
Add some El Dorado, Diplomatico, Botran, Dictador, Plantation and most importantly, Kirk and Sweeney to that list. Figure 40 bottles too. Never find yourself quoting Capt Jack Sparrow.. “Where do all the rum go!?!?!?”
Knottybuoyz
Jaysen wrote: Thu Mar 21, 2024 9:26 pm Seems a little light to me!
Ah so many fine rums left to enjoy and so little left of my liver. :lol:
Yours Aye! Rick
Users browsing this forum: Noles309, Yandex [Bot] and 1 guest
