VG23 New Build
Re: VG23 New Build
It is amazing how the labor hours increase with the size of the build. Time is the one thing most builders underestimate the worst.
Re: VG23 New Build
And how much longer the small things at the end take to do than the giant things at the beginning. So much faster to get a stack of plywood to look like a boat then a “hull shaped thing” to be an actual sea worthy vessel.
Re: VG23 New Build
Yep, thanks all! I totally agree with the comments. I read that, for commercial boat builders, finishing the hull is considered to be roughly 1/3 of the total build time. I've been reasonably accurate with estimates up to now, based on experience of construction from my previous build. Any delays have been due to unforeseen "life" stuff that you can't predict. But as the "construction" phase ends and the "finishing" phase begins, my estimates of time taken are bound to become more inaccurte as I've never built a boat this big/intricate before. The cockpit hatches and lids already took x2 my time estimate. Still, if I had a full year to work I reckon I'd be ready to launch by the end of this year. But with only 28 weeks max this year, I'm thinking it is guaranteed to drag on into 2025. That will be fine. I intended retiring completely on 31st Jan this year. It is now going to be early July but not a day longer...
For the build up to now there have been plenty of hard weeks and 10-12 hour days when I can (and also some slacking off!). Plus I've been doing the Westlawn courses too, and they've taken plenty of time as well. As Rick suggests, there will be plenty more long days and weeks to come too. But whatever happens it is making me happy. I'm learning and building and I'm 100% confident we'll have a boat in the water as soon as is reasonably possible.
Thanks to everyone for taking an interest in the build
Cheers,
Mick
Cheers,
Mick
Re: VG23 New Build
The big shops do finishing way different. For example the gelcoat is often put into the mold before the glass. This means the hull is “faired and finished” the minute it’s popped with only touchups required. That 1/3 number is really just about working the rigging and other stuff that we think of as the last 1/5 of the build.
That’s not to scare you off, but to let you know that you should not be bothered if your numbers suddenly balloon over your estimates. You’re not a pro. You’re not using their methods. You’re doing this as a hobby.
That said, you are crushing this build timeline. It will be interesting to see how you do from here.
Re: VG23 New Build
Some fruits of my recent travel.
Main sheet traveller track (Barton)
Rigging screws/turnbuckles (Petersen/Hayn)
Log (Walker's Excelsior IV)
Toggles from Petersen (for attaching standing rigging to mast) were delivered incorrectly - they've fixed it now, but I'll have to collect on a future visit.
The log was picked up cheap from a second-hand shop, but it appears completely un-used. A letter in the box states it was bought in 1972 but returned as it wasn't suitable for the boat (?). I won't be selling it, but in writing this post I checked and see there is one currently on EBAY for $615 and another for $900. Bit of work with the brass polish is in order I think...
https://www.scarboroughsmaritimeheritag ... rticle=619
Time to get back to work now. The boat won't build itself (sadly).
Mick
Mick
Re: VG23 New Build
Nice Mick!!! Jeff
Re: VG23 New Build
The missus is away for work this week, so time for a few of those long days mentioned previously. I've got the first primer on the boat in the port cockpit locker and the front compartment under the cockpit sole. Nothing shows up all the imperfections more than fresh paint, but regardless, I've made the decision to not excessively sand or fair any part of the boat that you can't normally see. So for these parts the rule is cursory sanding, System Three Primer, then paint, and that will be enough.
The open hatch won't be finished until the boat is turned over.
I'm only putting primer+paint on the first section under the cockpit sole. The other areas will be mostly inaccessible after the cockpit sole is on. Another coat of primer and two coats of paint and the sole itself can be fitted.
The port cockpit seat and hatch are practially finished and I'm working on the starboard seat now. These have been a real pain to get right but are almost done.
Mick
PS While away I read "Heavy Weather Sailing" by Adlard Coles. Decades old, but I understand why it is still in print. The sea doesn't change and some of the stories and tales in there are enough to make me take up croquet rather than sailing...
Mick
Re: VG23 New Build
Got the other side done.
Re: VG23 New Build
Nice Mick!!! Jeff
Re: VG23 New Build
Looking good!
